05-29-2007 09:14 AM
05-29-2007 02:42 PM
05-30-2007 09:47 AM
Does this happen every time you plug in this module? Has this module ever
worked? What happens if this is the only module in the backplane?
Will the power light be steady? Please try the module in a different
slot, with no other modules in the backplane. Does the power light blink
if you hot swap the module?
Also, can you please give me a list of equipment you are using in this
set-up? What is the part number of the power supply, backplane, and all
the modules you are using? I'd like to be able to reproduce your issue,
and think that replicating your system may be able to help in that.
Sorry for the barrage of questions, but I think we may need a bit more
information to be able to help you troubleshoot.
05-30-2007 10:59 AM
05-30-2007 11:02 AM
By part number, I was referring to the actual part number located on the label on the hardware. The reason I would like that is because I would like the revisions of each item.
05-30-2007 11:09 AM
Equipment List
1. Siemens SITOP 10 Power Supply 24VDC @ 10A
2. cFP BP4
3. 190-187K-03 (cFP2020)
4. 188054J - 02 (cFP AIO-610)
5. 190900C - 02 (cFP TC 125)
6. 187608G - 02 (cFP SG 140)
7. 191598-01 (cFP RLY 425)
05-30-2007 04:08 PM
05-30-2007 04:11 PM
05-31-2007 05:04 PM
Hi ab_man,
I have been unable to reproduce your specific issue, but believe that the
module may need to be returned for repair. Please contact National
Instruments to have your product RMA'd. You can create a new phone
support request at www.ni.com/ask.
Once you have RMA'd your module, please post your serial number on this
discussion forum post. Using the serial number, I can track your module
and intercept it when it is returned. Since I have been unable to
reproduce your issue, I'd like to take a look at your module.
Please let me know if you have any questions.
06-01-2007 09:03 AM
Here is the Serialnumber for the defective cFP-SG-140
Partnumber: 187608G-02
Serialnumber: 11F6991
Please let me know what you find out on this unit
