I've set some FP-20xx to "Obtain IP address from DHCP server". That is actually a dynamic IP, isn't it? Or will the FP stick to the IP that was given by the DHCP the first time?
Supposing it's dynamic, is it possible to assign a hostname to the FP thru the DNS server, so that i can refer to the FP for example as "blabla.domain.net" without the need to know the IP, which may change at every power up?
