07-26-2006 08:50 PM
08-07-2006 04:47 AM
Hi
Quick question are you using this in a network configuration or are you linking the tpc 2006 and cFP 2020 direct with crossover cable?
If you are testing this over a network then I would suggest swapping to a crossover cable and see if you get the same behaviour. I would also suggest upgrading or down grading your
Regards
Tim
10-01-2006 08:25 PM
Hi Tim, sorry I didn't get back to this thread earlier. I think the alert to a new post must have got lost somewhere in the interweb's ether 🙂
In answer to your question, I'm using a crossed CAT5 cable to connect the two together.
I am also using Labview 8 (PDA) on the 2006, and 7.1 on the 2020. However, when using my laptop instead of the 2006, still using LV8 on the laptop and 7.1 on the 2020, I get no disconnection at all. The connection speed is a steady 100 mbps, as shown by the green LED.
I'm starting to wonder if there is an error with my 2006 unit.
Disconnection still takes place between 10 mins and half an hour, wheter or not a 'button' is pressed on the 2006 screen.
10-04-2006 03:14 AM
10-04-2006 03:39 PM
