04-08-2015 10:14 PM - edited 04-08-2015 10:16 PM
I am trying to control several field point PLCs in a level tank. They are communicating through a FP-1000 module. I am able to add the devices through a configuration file in MAX. But there is an error saying " The device is offline. Make sure the device is connected and its power is on. " All of the field point PLCs have green light on for both " Power" and "Ready". I am not sure what the issue is here. I am using Labview 2014 and Field Point , VISA drivers are installed. Please see attached pictures for details.
Many Thanks
FLiu
04-09-2015 10:39 AM
My first thought is that you do have device driver issues. I believe either the latest LabVIEW, or the latest fieldpoint drivers are no longer compatible with the older Fieldpoint modules.
What versions of fieldoint and VISA are you using?
04-10-2015 10:30 AM
Thanks for your reply. I installed the most updated version for both ones. It turns out the configuration file for FP-1000 bank points to the wrong COM port for the Serial communication. I am able to communicate with the system now. I do have another problem through. I only have excutable labview files and a configuration file for the control system that I am working with. The original VI project file were lost. After importing the right configuration file in MAX, I installed the excutables and tried to run it. There is no response at all.The labview only last a few seconds and stopped. Any thoughts are greatly appreciated.
Fliu
04-11-2015 08:34 AM
It could be any number of things that are hard-coded into your executable that no longer match the way your system is set up now. Perhaps a file path that no longer exists. Or your MAX configuration isn't the right configuration anymore.
I don't know if you are going to be able to do much other than looking harder for the lost VI files, or rewriting them from scratch.
04-13-2015 03:56 AM
Thank you for your reply. I have couple questions :
(1) How would you suggest to design the excutables so that one installer can be used on many PCs with different COM ports set up ?
(2) Do I need to install MAX for excutables to run on a machine ?
FLiu
