FieldPoint Family
Connection of FP-RLY-420
Hello:
I'm planning to use FP-RLY-420 Modules for a proyect and I've been reading a bit about them. They require 2.5 W each and I've read that a Network module can only supply 9 W, so this would mean that I can only connect 3 FP-RLY-420 to each Network Module? Can I solve this situation powering the FP-RLY-420 modules with other supply different than the one used for the Network Module and other IO Modules?
Robst - CLD
Using LabVIEW since version 7.0
(3,116 Views)
Hi Robts
                     The FP-RLY-420 Module requires 1.7W (not 2.5 )
So, if your network module supply 9 W you can connect up to  5  FP RLY 420
National Instruments doesnt recommend to supply external power to this modules.
So If you need to connect more than five RLY 420 you would need to buy another network module. Robot Very Happy
Robts no dudo que puedas optimizar los canales de tus modulos para aprovechar el hardware que ya tienes al maximo
Dame mas informacion al respecto para poder recomendarte una configuracion.
Espero que pronto puedas correr exitosamente tu aplicacion
saludos Smiley Happy
Erwin Franz
Certified LabVIEW Architect, Certified TestStand Developer
(3,099 Views)
Here is the link where I found the Power requirements of your module
Smiley Happy
http://www.ni.com/pdf/manuals/321904a.pdf
Erwin Franz
(3,098 Views)
Hola que tal:
Gracias por responder, bueno, mi aplicación necesita 7 módulos FP-RLY-420, 2 FP-AI-111 y un FP-AI-200.  De todas maneras ya necesitaba dos módulos de red Smiley Happy  Estaremos utilizando FP-1000. O sea que podría conectar a un módulo de red 5 FP-RLY-420 y los restantes módulos al otro FP-1000 y de este modo todos los módulos estarían alimentados, es correcto?
Gracias de antemano!
Robst - CLD
(3,091 Views)
Hello Robst
For Systems which need a large number of relays, we prefer using 24vdc external relaye, and FP-DO-401 .
A 8 slot base can oparete up to 128 relays !, and  you can use very small relays on "DIN" rail, that keep the system quite compact.
No special power supplay needed .
help ?
___________________
Try to take over the world!
(3,082 Views)
