10-13-2008 02:01 PM
I don't know if this has been pointed out already or not, but I am not able to attach files while using Google Chrome. Firefox is fine.
10-13-2008 02:27 PM
Yes, it has been pointed out here.
You should be able to attach files with three letter extensions (images, etc.) it seems only the attachment of Vis (*.vi, two letter extension!) is broken in Chrome and Safari.
02-17-2009 07:35 AM
altenbach wrote:You should be able to attach files with three letter extensions (images, etc.) it seems only the attachment of Vis (*.vi, two letter extension!) is broken in Chrome and Safari.
Note that is only broken when the web server is broken. I can successfully upload files to other host webservers with *.vi extensions. This is a Lithium/Server problem not a browser problem. Fix Lithium.
