Benchtop Measurement and Test
High-Performance Test
Systems Engineering Software
09-26-2014 09:58 PM
In the remote control editor there is no option to generate code. This is for an FTC team. Also There is also no telop mode. If anyone has had this problem how would I fix it. I am using Lab View 2012.
09-27-2014 10:46 AM
In order to get the code generation button you need to install the LabVIEW toolkit for MINDSTORMS competition. Once you install it you should be good to go.
Cheers
Hunter
Thanks!
We'll be in touch soon!
