FIRST Robotics Competition Documents
[FRC 2016] NI Software Set Up Guide
Software
NI has 2 installers for FRC 2016.
The "NI Software for FRC 2016" content contains industry standard versions of LabVIEW, Real-Time, Vision, PID, and the FRC Simulator. This content is available via download or on the NI Software DVD in your kit of parts.
The FRC 2016 Update Suite contains all of the FRC Specific content for LabVIEW as well as the Driver station and Utilities that ALL FRC teams will need to install.
Check the options below if you are not sure what you need to download and install.
Installation instructions are included in the What Should I Install? section below.
   The FRC Update Suite Password is: @Ahead)Together!FRC^2016
Activation
Both the "NI Software for FRC 2016" and the FRC Update Suite will need to be activated. You can find your team's unique serial number on the back of the DVD envelope that is included all teams Kit Of Parts.
The serial Number should start with an 'M'
If you want to install software before you receive you kit of parts just leave the serial numbers blank and LabVIEW will be installed as a trial.
You can Activate LabVIEW after installation using the NI Licence Manager. (Start>Programs>National Instruments>NI Licence Manger
What should I install?
Option 1: Your team is programming in LabVIEW
     Download and Install all components of NI Software for FRC 2016
     then Download and Install FRC Update Suite
     then restart your computer
Option 2: Your team is using C++ or Java but wants to use NI Vision
     Download the NI Software for FRC 2016 and install vision only
Option 3: Your Team is using C++ or Java and only need the required competition software
     Just download and Install the FRC Update Suite
Still want to use a 4-slot or 8-slot cRIO? Install FRC 2014 Software:
The 4-slot and 8-slot cRIO controllers can no longer be used for FIRST competitions.  But you can still program these controllers for use in demo robots. You will need to use the NI Software for FRC 2014 installer and the FRC 2014 Update Suite (links below). You will also need the serial number from your FRC 2014 Kit of Parts to use this software.
Download the 2014 NI Software for FRC
Download the 2014 Update Suite
Comments
marc.center
on
After Installing the FRC2016 Labview software the NI system checked for updates and found some. Should I install the updates?  BTW, last year installing the updates caused problems and users needed to remove the updates in order for the 2015 FRC Control System to operate.
ToeTickler
on
What software did it find updates for?
TowerViewBlues
on
im haveing troubles trying to have our system to pick up any update with the NI softwear anyone know how to help me out?
ToeTickler
on
Which software are you trying to update?
ikelli
NI Employee (retired)
on
You may not have any available updates depending on when you downloaded the software.  Which update are you trying to receive?
You can verify your update service is set correctly by navigating to Start»All Programs»National Instruments and launch NI Update Service.  From there, navigate to File»Preferences.
Make sure the Enable periodic checking box is selected.
Kelli Kravetz
Product Marketing Manager
LabVIEW, LabVIEW NXG, LabWindows/CVI, Measurement Studio
netsirk
on
Hi everyone,
Keep in mind that you should not apply any optional upgrades. These may install over FRC dependencies which could break your code.
Kristen M
Automated Test Product Marketing Engineer
mrbbking
on
How many times can we use the activation code? Our team has more than one system we'd like to use.
johneev
on
I down loaded NI_FRC2016.zip --extracted the files and ran setup --input my serial number--did the reboot when told--opened labview successfully all went well....Until I then downloaded the FRCUpdate2016.0.0.zip file --When I try to extract all I get a message saying that the files are password protected -- any ideas?
marc.center
on
1) Did you use the password that was provided at the FRC Kickoff? I would
try this one.
2) Sometimes rebooting your PC helps. You might want to try that before
trying to download the update. It might help as well,
apriltalksrobots
on
@mrbbking,
The activation code will work for up to three computers. This will allow your team to use more than one system.
1138Eagles
on
Use the password that you were given at kickoff to unzip the game manual (Look on the FRC website if you don't know what that is.
Mattfiles
on
Can Someone tell me what to do if My team lost their liscense number? Id there a place online to find it or can I request a new one?
ToeTickler
on
Please call into support and we can help you with that.
ericalbers
on
Where can we find a serial number???  We lost/no longer have the cardboard sleeve from the DVD!
Our roborio has to be flashed to use this weekend at Northbay competition?????
Is there a default serial number we can use?
I.B.Hating
on
If you do not choose to activate LabVIEW or any other NI product it will be installed in evaluation mode for 30 days.
Brian H. -- Electronics & Measurements Product Marketing Manager
apriltalksrobots
on
You can also call in to NI Support at 866-511-6285 for help with your activation!
Contributors
