Hello!
The FRC 2014 software (from last season) should be licensed indefinitely. It sounds like it might not be fully activated.
Can you open the NI License Manager and take a look at the color of the boxes next to the software? The link below explains what licensing status is indicated by each color.
http://zone.ni.com/reference/en-XX/help/371136F-01/nilm/html/environment/
If the boxes are not all green, then your software is likely not fully activated. If they are and you're still experiencing the same problem, then I would recommend giving NI FIRST Support a call at 866-511-6285
Best of luck this season!
Kelly B.
