FIRST Robotics Competition Discussions
FRC 2012 cRIO project error
We have LabView running but when we try to create the FRC cRIO Robot Project we get an error that a vi is missing (see complete error message below).
Hardware: FRC cRIO I  (not II)
Installation sequence:
installed LabView {everything} (from USB Drive from 2012 Kickoff) and activated with FRC serial #.
installed the FRC 2012 LabView Update from NI website.
installed the FRC 2012 LabView Utilities Update from NI website.
installed the FRC 2012 LabView Driver Station Update from NI website.
My understanding is you do not need to have any hardware to create a cRIO Robot project.  The hardware is only necessary when you want to run the code.
Could you confirm that we have to setup the cRIO, Axis Camera and Robot Radio (per Getting Started list of tutorials) before creating that project?
If this is the reason for the error, is there ANY other way to virtually setup the RT hardware WITHOUT having to physically connect to it first?
ERROR MESSAGE:
Error 7 occurred at Open VI Reference in FRC Create Project.vi->FRC Wizard - Robot.vi
Possible reason(s):  LabVIEW:  File not found. The file might have been moved or deleted, or the file path might be incorrectly formatted for the operating system. For example, use \ as path separators on Windows, : on Mac OS X, and / on Linux. Verify that the path is correct using the command prompt or file explorer.  VI Path: C:\Users\DALE\Documents\LabVIEW Data\2012-beta Robot Project\Dashboard Datatype.ctl
Message 1 of 9
(8,965 Views)
Hi Dale,
I got that same error. I uninstalled Labview and all it's components for FRC and re-installed making sure I ran using "autorun.exe". I don't know why it worked after that, but it did.
You don't have to have the cRio hooked up to create a project, or edit it. Only to run it.
Joe V
FIRST Team 704 mentor
"Lockheed" Joe
Testing Blog"
Message 2 of 9
(4,407 Views)
Joe,  Thanks,  I already reinstalled it once, but I did not reinstall using "autorun.exe".  I wll make sure and use the autorun option this next time. Dale
Message 3 of 9
(4,407 Views)
Joe, thanks for the suggestion; however I just finished the reinstall of LabView for the 4th time (using autorun.exe) after uninstalling ALL installed National Instruments programs and further erasing all folders under National Instruments folder in c:\Program Files\ and then installing directly from the original USB drive provided at Kickoff.
Same Error: Error 7 occurred at Open VI Reference in FRC Create Project.vi->FRC Wizard - Robot.vi
Possible reason(s): LabVIEW:  File not found. The file might have been moved or deleted, or the file path might be incorrectly formatted for the operating system. For example, use \ as path separators on Windows, : on Mac OS X, and / on Linux. Verify that the path is correct using the command prompt or file explorer.  VI Path: C:\LabVIEW_Projects\Dashboard Datatype.ctl
Any suggestions on what to try next?
Message 4 of 9
(4,407 Views)
It looks to me like this error is because LabVIEW is trying to open a file that doesn't exist in the path it was given.  I suspect the reason is that the wizard failed to get the file copied to the expected location.  By wizard I am talking about the tool that creates a new robot project for you.  When you run the wizard it applies your configuration, copies files into a project for you, then opens the project.  If the copy fails, then the open will fail.
I'm guessing here, but maybe this is a permissions problem.  Have you tried running as administrator, turning off windows firewall, etc.?
You could also check to make sure the files used by the wizard exist.  For example Dashboard Datatype.ctl should be located here:
LabVIEW 2011\resource\plugins\NewDialogFiles\ProjectWizards\FRC\FRC Templates\Robot
and here:
LabVIEW 2011\resource\plugins\NewDialogFiles\ProjectWizards\FRC\FRC Templates\Robot\Real VIs
If it is missing, I would suspect an installation issue.
You might also look in the project folder where you told the wizard to create the project, and see if any files exist there.
Message 5 of 9
(4,407 Views)
Doug,
Thanks for the suggestions.
The file “Dashboard Datatype.ctl”  exists in the C:\Program Files\National Instruments\LabVIEW 2011\resource\plugins\NewDialogFiles\ProjectWizards\FRC\FRC Templates\Robot\Real Vis\
I then turned off the McAfee Firewall and tried to execute the FRC cRIO Robot Project.  I got the same error message.
I then restarted LabVIEW 2011 with “run as administrator” and tried to execute the FRC cRIO Robot Project.  I got the same error message.
Error 7 occurred at Open VI Reference in FRC Create Project.vi->FRC Wizard - Robot.vi     Possible reason(s):  LabVIEW:  File not found. The file might have been moved or deleted, or the file path might be incorrectly formatted for the operating system. For example, use \ as path separators on Windows, : on Mac OS X, and / on Linux. Verify that the path is correct using the command prompt or file explorer.  VI Path: C:\Users\DALE\Documents\LabVIEW Data\2012RobotProject_6\Dashboard Datatype.ctl
In the folder “C:\Users\DALE\Documents\LabVIEW Data\2012RobotProject_6\”  there are only two files: “2012RobotProject_6.lvproj”, and “2012RobotProject_6.aliases”.  NOTE: I am using Windows 7 Ultimate SP1.  Also, the path displayed in Windows explorer sometimes shows “My Documents” and sometimes shows “Documents”  is it possible that different function/procedure calls are being used inside this Wizard such that some of them try to use the “literal” path instead of using the correct relative path for this O/S?
Finally,  I changed the Paths in LabVIEW to point to C:\LabVIEW_Data\ to remove o/s tricks with paths using “My documents”.  I reran the Wizard.  I got the same error and the same two files were loaded into the project folder in the new path.
Dale
Message 6 of 9
(4,407 Views)
