02-15-2014 03:25 PM
Does anyone know where the source is for the 2014 dashboard (i.e Dashboard Main.vi)?
Thanks!
Jack Wilson Mentor Team 2930
Solved! Go to Solution.
02-15-2014 03:29 PM
In the Getting Started Window, create a new dashboard project. That will start out with the source to the default dashboard.
02-15-2014 03:45 PM
Unforunately that shows Dashboard Main.vi as not being found
02-17-2014 02:00 PM
Can you browse to the directory that you created that project in and see if it's just named slightly different?
02-17-2014 02:11 PM
Nope, It seems everything else is there.
02-17-2014 02:34 PM
I just created a dashboard project from the Getting Started Window and it worked for me. This is the prefered way to get Dashboard Main.vi. If that isn't working, you may have a folder set to read-only, or perhaps the source got deleted.
To answer your question, the source of the Dashboard Project (where the wizard copies it from) lives here:
C:\Program Files (x86)\National Instruments\LabVIEW 2013\ProjectTemplates\FRC Templates\Dashboard
02-17-2014 03:35 PM
Hi Doug,
All the other files are there except dashboard main.vi. Before I go and reinstall everything (a process of hours), only find out it isn't there still (I already did it on 2 computers), can you post it for me?
Thanks!
Jack
02-17-2014 06:12 PM
Hi Jack,
Here is Dashboard Main.vi. I cannot guarantee it will run for you as you could also be missing some other files. You could try to repair the installation rather than uninstall/reinstall by going to the Control Panel>>Add/Remove Software>>National Instruments, selecting the FRC software and choosing repair. This process can sometimes restore missing files from the installation. Please let us know if you have further questions.
02-17-2014 09:37 PM
Thanks Holly, that's exactly what I needed.
Jack
