Examples and IP for Software-Designed Instruments and NI FlexRIO
NI PXIe-5645R 6 GHz Vector Signal Transceiver, with Baseband I/O
NI-RFSA and NI-RFSG Instrument Driver FPGA Extensions Examples
<hr>
NI Instruction Sequencer and SPI Example for the NI PXIe-5644/45R »
This example uses NI-RFSA and NI-RFSG instrument driver FPGA extensions, along with the instruction sequencer and SPI IP to create FPGA personalities for the NI PXIe-5644R and NI PXIe-5645R that have the ability to issue sequences of SPI commands for hardware-timed DUT control.
NI I2C Host Example for the PXIe-5644/45R »
This example uses NI-RFSA and NI-RFSG instrument driver FPGA extensions, along with the NI I2C IP to create FPGA personalities for the NI PXIe-5644R and NI PXIe-5645R that have the ability to implement I2C communication for hardware-timed DUT control.
NI RFFE Host Example for the PXIe-5644/45R »
This example uses NI-RFSA and NI-RFSG instrument driver FPGA extensions, along with the instruction sequencer and SPI IP to create FPGA personalities for the NI PXIe-5644R and NI PXIe-5645R that have the ability to implement RFFE commands for standard specific hardware-timed DUT control.
NI SPI Host Example for the PXIe-5644/45R »
NI Static Digital Host Example for the NI PXIe-5644R/45R »
This example uses NI-RFSA and NI-RFSG instrument driver FPGA extensions, along with the instruction sequencer and SPI IP to create FPGA personalities for the NI PXIe-5644R and NI PXIe-5645R that have the ability to implement static digital communication and control.
Power Servoing Host Example for the NI PXIe-5644R/45R »
This example uses NI-RFSA and NI-RFSG instrument driver FPGA extensions, to level the output of an RF power amplifier by iteratively measuring its output power and adjusting the supplied stimulus.
NI Noise Generation Host Example for the PXIe-5644/45R »
This example uses NI-RFSA and NI-RFSG instrument driver FPGA extensions to adds AWGN to a waveform in real time on the FPGA of a PXIe-5644/45R. The noise is generated using the NI Noise Generation IP.
Slot Power Host Example for the NI PXIe-5644R/45R»
This example implements Slot Power measurments via RFSA and the NI Slot Power IP Host API.
NI JTAG Host Example for the PXIe-5644/45R »
This example uses NI-RFSA and NI-RFSG instrument driver FPGA extensions, along with JTAG standard signal commands for use in boundary scan testing of ICs and printed circuit boards.
Streaming Host Example for the NI PXIe-5644R »
This example uses NI-RFSA and NI-RFSG instrument driver FPGA extensions, along with the Stream Controller IP to stream data from the host VI to the output port of the NI PXIe-5644R as well as from the input port of the NI PXIe-5644R to the host VI. This example also provides a template for setting up peer-to-peer streaming with another device.
Verified Application IP
<hr>
DSP
Channel Emulation IP »
This IP implements inline, real-time DSP in LabVIEW FPGA to apply arbitrary channel models to RF data. Fading profiles are computed in real-time on the host, and dowloaded to the FPGA where they are interpolated and applied to the data stream.
NI Instruction Sequencer IP »
This IP contains a memory to hold sets of instructions, called sequences, which can be issued from the IP on the FPGA to another component on the FPGA, such as a digital protocol generator. This facilitates FPGA-based reconfiguration.
NI Noise Generation IP »
This IP enables the generation of both uniform and additive white Gaussian (AWGN) noise using an NI LabVIEW FPGA device.
Bandwidth Power IP »
This IP uses an FPGA-based algorithm to calculate power in an input signal across the entire bandwidth.
Programmable Filter IP »
This IP implements a 33 programmable tap FIR Filter on an FPGA.
Slot Power IP »
This IP uses an FPGA-based algorithm to calculate power in an input signal across discrete time slots.
Stream Controller IP »
This IP controls the writing and reading of data to and from FIFOs on the FPGA.
Control
Power Servoing IP »
This IP uses an FPGA-based control loop to rapidly adjust device output power to reach a desired input power, when an load or amplifier of unknown gain is connected between the output and input.
Digital Protocols
I2C IP »
This IP implements inter-integrated circuit (I2C) communication, including support for both master and slave functionality.
SPI IP »
This IP implements serial peripheral interface (SPI) communication, including support for both master and slave functionality.
RFFE IP »
This IP implements MIPI RF front end (RFFE) communication, including support for both master and slave functionality.
Contributors
