Overview
This example demonstrates how to use VideoMASTER to perform a closed captioning test on a video binary file.
Description
In this example, it explains how to perform a VideoMASTER closed captioning test on a video binary file (.vbf). A video binary file is a recorded video file that you can perform tests after the data has been acquired.
Requirements
- LabVIEW 2012 (or compatible)
- VideoMASTER 3.0.0 (or compatible)
- Specify Measurement Locations File path,Video Binary File path and other related configuration
- Run the LabVIEW API Off-Line CC 2012 NIVerified.vi
Even videoMASTER 3.0.0 (or compatible) has been setup, user needs to locate related subVIs from videoMASTER installation path manually. LabVIEW can not locate related subVIs automatically
VI Snippet
Jim St
RF Product Support Engineer
