Overview
In this example, we show how LabVIEW can be used to interface with the Hokuyo URG-04LX-UG01 Laser Range Finder.
Description
The URG-04LX-UG01 is a small, low cost, bus powered LiDAR that can be easily used to acquire fast and accurate distance measurements across a 240° range. The attached code below can be used not only for visualising a simple algorithmic depiction of how a USB device can be controlled using the NI-VISA drivers, but also can be used as API to be integrated within larger application frameworks based upon acquiring distance measurements from the URG-04LX-UG01.
Requirement
NI Snippet
It is recommended that when analyzing the LabVIEW code, you also have access to the accompanying datasheet for the URG-04LX-UG-01 which outlines the specifications of the SCIP 2.0 communications interface.
Edit: I was getting error: Invalid buffer mask specified but I followed this white paper instead and it worked.
