Example Code
Triggered GigE Acquisition
Products and Environment
    Hardware
  • Data Acquisition (DAQ)
  • Machine Vision
    Driver
  • NI Vision Acquistion Software
Code and Documents
Overview
This example uses a DAQ device to create a pulse train in order to trigger an image acquisition.
Description
GigE Cameras are generally triggered via an external trigger line; the trigger method itself is described by the camera's manufacturer in the GeniCam XML File.
In this particular example, a DAQmx task is created to generate a pulse train; this pulse train ought then be wired into the camera's trigger line to control the Grab. The example thus requires a DAQ Device that possesses a counter output and is compatible with DAQmx. A property node is used to allow the user to chose the desired trigger mode.
  1. Select the camera to be used
  2. Enable triggered mode as well as the desired trigger activation and Timeout.
  3. Select the counter to be used
  4. Select a frequency for the counter
  5. Run the VI
Requirements
Hardware
This example requires a GigE Camera with an external trigger line. In order to trigger the camera, a DAQ device with a counter output is used; as such, an external connection must be made between the DAQ device and the camera. The DAQ device must be compatible with the DAQmx driver.
Software
LabVIEW 8.6 "or compatible"
Vision Acquisition Software 8.6 "or compatible"
NI DAQmx 8.6.1 "or compatible"
VI Snippet
**This document has been updated to meet the current required format for the NI Code Exchange. For more details visit this discussion thread**
Andy Chang
LabVIEW Control Design and Simulation
Comments
marleen
on
Thank you AndyC! I am also trying to trig my GigE camera with a DAQ device. Your tutorial gives me useful ideas! (but unfortunately I can't run it since I only have Labview 8.2.1...)
Neo6
on
Thnx Andi... very helpful for my work
Contributors
