On a deployment computer, the sequence editor or a full featured user interface may not be available. This example provides access to the TestStand configuration menu in a small application
This example uses the TestStand User Interface controls to create a simple application which exposes the TestStand configuration menu. After logging in as a user with configuration privileges, you can use this tool to configure TestStand options. The tool is implemented in LabVIEW and CVI along with the source code.
TestStand Configuration Tool - TS2019.zip
TestStand 2019 or compatible
LabVIEW 2020 or compatible (to view and edit LabVIEW source code)
LabWindows/CVI 2015 SP1 or compatible (to view and edit CVI source code)
TestStand Configuration Tool - TS2016 - NI Verified.zip
TestStand 2016 or compatible
LabVIEW 2016 or compatible (to view and edit LabVIEW source code)
LabWindows/CVI 2013 SP2 or compatible (to view and edit CVI source code)
TestStand Configuration Tool - TS2012 - NI Verified.zip
TestStand 2012 or compatible
LabVIEW 2012 or compatible (to view and edit LabVIEW source code)
LabWindows/CVI 2013 or compatible (to view and edit CVI source code)
TestStand Configuration Tool - TS4_0.zip
TestStand 4.0 or compatible
LabVIEW 7.1 or compatible (to view and edit LabVIEW source code)
