Overview
Synchronize a Counter (Angular Encoder) task with an Analog Input task.
Description
This VI will take data at the same rate from both a counter input task, set up here to be an angular encoder, and an analog input task. The Analog Input sample clock is used as the sample clock for both tasks, such that they will both acquire data at the same rate. This VI will also take the counter output and place it into a waveform with the same timing information as the analog data. This allows all the data to be plotted on the same graph.
*Note: The "Get Terminal Name With Device Prefix.vi" subVI automatically selects generates the full terminal name (such as Dev1/ai/sampleclock) and routes it to the sample clock source for the counter. If this subVI does not load, you can easily create a control for the counter's sample clock source and select DevX/ai/sampleclock where DevX is the device name of your DAQ card. The "Get Terminal Name With Device Prefix" VI simply does that behind the scenes rather than needing a user to select it
Requirements to Run
Software
Hardware
Block Diagram
Does anyone know if this works with a CI Freq input instead of a encoder? I've attempted to use it for that purpose but I'm frequently getting a "Multiple sample clock pulses were detected within one period of the input signal" error. I'm guessing it stems from the input signal not being fast enough (it's a tach with just one pulse per revolution).
In This configuration, is there any way to measure speed (angular velocity) from the position data and synchronize it with voltage measurement? I mean measure angular velocity form the position while defining sampling rate & samples per loop?
This site uses cookies to offer you a better browsing experience. Learn more about our privacy statement and cookie policy.
