Example Code
Programmatically Set Front Panel Size and Position
Code and Documents
Introduction
This example allows the user to specify the position of each border of the front panel. The panelbounds property adjusts the actual pane borders, not including the window borders, scroll bars, tool bars, title bar, etc., so ensure that there is sufficient clearance on all sides if you wish to see anything outside the actual front panel pane. Position values are in pixels and are in terms of absolute screen position (i.e. 0 is the top or left most pixel on your monitor).
Instructions
  1. Open the VI.
  2. Enter the desired pixel coordinates for the 4 sides of the front panel.
  3. Run the VI.
The VI will position the borders of the front panel to the specified positions.
Additional Notes
Caleb Harris
National Instruments | Mechanical Engineer | http://www.ni.com/support
Comments
shb
Active Participant
Active Participant
on
How can I set the size of panes? (When there are splitter bars.)
NiCoder
Member
Member
on
Introduction
Instructions
  1. Open the VI.
  3. Run the VI.
Additional Notes
Ajay_MV
Active Participant
Active Participant
on
Is there any property to change the hight and width of the window in run-time?  All I can see is that I need to give all four co-ordinates (top, left, right, bottom) in order to achieve this.  I wouldn't like to give the top and left, but only the area height and width to change the window size.  Is it possible?
crossrulz
Knight of NI Knight of NI
Knight of NI
on
It looks like you will have to do something like this
GCentral
Contributors
