Overview
This VI demonstrates how to set a camera attribute using NI Vision Development Module.
Description
In order to use the IMAQdx property node to programmatically change an attribute, you need to know the full name of the attribute.
This example populates a list of all the available attributes for your IMAQdx camera and set an attribute.
Requirements
Software
- LabVIEW Base Development System 2012 (or compatible)
- NI Vision Development Module 2012 (or compatible)
- If running in a Real-Time context, you will need the LabVIEW Real-Time Module 2012 (or compatible)
Hardware
- Download and open the attached ZIP-file
- Open the VI and follow the instructions inside
**The code for this example has been edited to meet the new Community Example Style Guidelines. The edited copy is marked with the text ‘NIVerified’. Read here for more information about the new Example Guidelines and Community Platform.**
