Example Code
Programmatically Reset USB DAQ device in LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example demonstrates how to programmatically reset a USB DAQ device that has been unplugged and then reconnect and continue running in LabVIEW.
Description
If you want to start with the device unplugged, you will need to right click the DAQ assistant and choose Generate DAQmx code. This will allow you to choose the appropriate device prior to starting the VI.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Run the VI with your device plugged in and working.
  2. Unplug or remove the device and you will notice that it go to the reset loop and waits for device to be reconnected.
VI Snippet
Applications Engineer
Comments
Assaf Yarden
on
Very elegant solution, Tahnks
J.C._Andersen
on
Who made this code look so shitty!?
This code might work as intended but you would fail a CLD exam if this was the level of tidiness you delivered.
NI, you need to do better than this in ALL of you example code. You will make beginners think that it OK to be sloppy when programming and that just  destroys code quality in general. That will in turn give LabVIEW a bad reputation for. You need to do better. I know this is an old code sample, but it is still online, and you need to make sure that all the code than is presented online at least will pass the minimum requirements for passing your own certifications.
Please step up.
Best regards
Jens Christian Andersen.
CLA, CTA, CPI
