Overview
Copies files from a remote NI Real-Time (RT) target to the local host
Description
This VI uses FTP functions to programmatically copy all the files in a directory (user specified) on the real time target to a directory (user specified) in the host PC. The type of each item in the directory in the RT target is first established and only the items of type 'file' are picked. The array containing paths to all these 'file' items is built . This is then built into an array of clusters (which is the data type expected by the 'FTP Retrieve Multiple.vi')
Requirements
Additional Information or References VI Block Diagram
VI Block Diagram
Hi. I want to transfer files from the host PC to RT target. Any idea how to do it?
I am also looking for the same i need to transfere the file from host to RT
This will not work untill configuring the FTP server in the windows, which is disabled by default.
Thank you, Supreeth, for sharing this very useful vi.
One comment - I was trying to transfer .zip files and though the files were transferred, they could not be opened. When I set the file type to binary (boolean in the last FOR loop set to TRUE), it worked.
Thanks for the feedback WWST.. you are right the 'false' value works only for ASCII files...
In trying to transfer TDMS files, I had to set Active(T) = False for FTP Directory Listing.vi and FTP Retrieve Multiple.vi to get this to work.
I also Ignore the NI message for "Thanking me for using NI FTP"
Hi All,
I am trying to programmatically copy files from my PC to my cRIO. The above screen shot is what my block diagram looks like. I ran this routine, I didn't get any error message, however, I didn't see a copy of the file in the folder I specified on the cRIO after I opened it . I have double-checked the filenames and paths, and they are as I want but the copied file isn't showing up on the cRIO. Please can anyone help me solve thi issue?
Please how can I configure the FTP server as you mentioned? I tried to implement "aveo's" routine, I got no errors, but I didn't see the file(s) I "copied" to the cRIO.
