Overview
This project is a modified version of the 10-Tap 8-bit Camera with DRAM shipping example, for the PCIe-1473R-LX110 FPGA CameraLink FrameGrabber. The project has been configured to use the PCIe-1473R with the larger Virtex-5 LX110 FPGA, where the shipping example is configured to use the standard PCIe-1473R with a Virtex-5 LX50 FPGA.
Description
This example demonstrates how to acquire images from a 10-tap, 8-bit, extended configuration, Camera Link camera and display the images on the host. This example supports area scan and line scan cameras for both continuous and finite acquisitions.
This example also demonstrates the use of DRAM as a frame buffer for very high speed acquisitions. Data packing and flow-control are also employed to maximize use of the available DRAM and FIFOs in terms of both memory space and performance.
Additionally, the example demonstrates the serial server, which allows third-party camera configuration utilities to communicate with the camera using the Camera Link serial interface while this VI is running.
Requirements
Software
LabVIEW 2014 or later
LabVIEW FPGA Module 2014 or later
LabVIEW Vision Acquisition Module 2014 or later
Hardware
PCIe-1473R-LX110
Download Link (Size: 354 MB)
https://drive.google.com/file/d/0B9-DkLZ_BGmUVEh3aXZnMk5kNVU/view?usp=sharing
I am working with NI PCIe 1473R-LX110 in my project. I am using a different camera then this Basler camera curently. Recently I have been looking to move to the Basler camera with the Cimosis CMV2000 Sensor that has 10 Taps.
Basler isn't recomanding to use this camera in 10Tap mode. They recomand maximum of 8Tap mode.
My issue:
I see the code is using CLIP that Pack the data from 80bit to 256bit and from 256bit to 64bit.
How do I create packer like that for difrent Tap configuration.
Thanks - Amit,
Dear,
Hello~~, I'm Mr. Jin and got the error message attached below.
You must reload the DRAM declaration file.
FPGA Target 2 (RIO0, PCI2-1473R-LX110)
I selected DRAM Bank0 and Bank1 and then reloaded but the error message was appeared.
How can I solve that ?
Best wishes,
From Jin ( kcjin000@gmail.com )
Hey Amit,
I would probably go with Basler suggestion to use 8-tap. I have not configured a project for 10-tap before. You will want to post on the forums since someone probably has done this before, and could save you the time.
http://forums.ni.com/t5/Machine-Vision/bd-p/200
Frank
Hi Jin,
I have not seen that error before. I would try the forums also: http://forums.ni.com/t5/Machine-Vision/bd-p/200
Frank
Hi Frank, I was asking specifically on the CLIP used in this example to pack the data from 80bit to 256bit. How did you configure this CLIP? It is in the code? Thanks - Amit,
DRAM Bank 0, DRAM Bank 1 is component-level IP.. Where is located ?
Pack80 to 256 and Pack 256 To 64 are located C:\Program Files (x86)\National Instruments\LabVIEW 2014\examples\Vision-RIO\Common\CLIPs...
Best Regards,
From Jin
Do you know how to create a new CLIP with different Packing / Unpacking configuration?
Does this example work with interlaced or section tap configuration cameras in 10 tap - 8 bit?
This site uses cookies to offer you a better browsing experience. Learn more about our privacy statement and cookie policy.
