Example Code
How can I have a Waveform Chart using a Waveform Graph?
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example demonstrates how to use a Waveform Graph as a Waveform Chart.
Description
This VI shows how to implement a graph with chart behavior.  A graph plots all the available datapoints at once so in order to update it at each iteration like a chart the VI updates the data. In this case a random value is used as data. At the first iteration it initializes all the datapoints on the graph to zero then each iteration the new data is inserted at the end of the array and the waveform is rebuilt.  The x-axis scrolls with the data as it updated.
Requirements
 Software
  • LabVIEW Base Development System 2012 (or compatible)
  • If running in a Real-Time context, you will need the LabVIEW Real-Time Module 2012 (or compatible)
 Hardware
  • No hardware is necessary to use this example VI
  1. Download and open the attached file
  2. Run the program
undefined
undefined
Why Can I Not Use Cursors in a Waveform Chart?
**The code for this example has been edited to meet the new Community Example Style Guidelines. The edited copy is marked with the text ‘NIVerified’. Read here for more information about the new Example Guidelines and Community Platform.**
Matteo Brunella
Application Engineer
NI Italy
Comments
mlok
NI Employee (retired)
on
The dt input in this sample is incorrect.
The correct units are seconds, so the milisecond input "Time Interval Between Points" should be divided by 1000 first before being input into the Waveform "dt" input.
