This example demonstrates how to query the column headers together with the content of the columns from a database.
Description
The Database Connectivity Toolkit offers multiple ways to query the content of a database table. You can use the DB Tools Select Data VI or the DB Tools Execute Query VI to get the content of a database table.
Both functions return the content of the table, but not the name of the corresponding columns. It is possible to get the column names with a SQL Query, but this query is different for each Database Management System (DBMS).
This example will push a test table named TestTable with some test data into LabVIEW.mdb. The Rec GetData VI (<labview>\addons\database\Recordset.llb\Rec GetData.vi) is used afterwards to get a reference to the recordset which offers a name property which provides the column names.
Requirements
Software
Hardware
Note: You cannot use this example on RT targets. The Database Connectivity Toolkit uses ActiveX to access the database. ActiveX is a Windows only technology and not available on RT targets.
**The code for this example has been edited to meet the new Community Example Style Guidelines. The edited copy is marked with the text ‘NIVerified’. Read here for more information about the new Example Guidelines and Community Platform.**
thank you very much ,so by your code i got the way to get the columns of the table.thanks very much.
This site uses cookies to offer you a better browsing experience. Learn more about our privacy statement and cookie policy.
