Overview
This example VI show how to retrieve information from a table in database which has columns defined as Date/Time data type.
Description
This example has been tested with Microsoft Access 2013 and the most important is that you can retrieve information from a table in database which has columns defined as Date/Time data type. The most important in this example is to show you how to build your query since TimeStamp in LabVIEW must be reformatted in order to get a Microsoft Access valid format.
This example has been built with an Event Producer Consumer structure. You can execute two specific queries:
SELECT * FROM table_name
SELECT * FROM table_name WHERE column_with_dates BETWEEN time_stamp_1 AND time_stamp_2
Requirements
LabVIEW 2012 (or Compatible)
Database Connectivity Toolkit 2009 (or Compatible)
Access 2013 (or Compatible)
- Run the Vi
- If necessary, modify query parameters
- Retrieve all data or Execute query and look at the results
VI Block Diagram
