Example Code
DAQmx Acquire with Multiple Channel Input Ranges
Products and Environment
    Hardware
  • Data Acquisition (DAQ)
    Software
  • LabVIEW
    Driver
  • NI DAQmx
Code and Documents
Overview
  This VI shows how to use DAQmx to acquire data from multiple channels each with their own Input Range.
Description
This code shows how to use DAQmx to acquire data from multiple channels each with their own Input Range. The code also displays the data of each channel separately.
Requirements
Software
  • LabVIEW 2012 or compatible
  • NI-DAQmx 9.5.5 or compatible
Hardware
  • NI Multifunction DAQ Device
  1. Configure the parameter for the right channel and device
  2. Connect your hardware appropriately
  3. Run the VI
 Front Panel
Block Diagram
Ben Sisney
FlexRIO V&V Engineer
Comments
dPMU
Member
Member
on
I am new to labview. I am wondering will this vi simultaneously read from two or more channels?
