Example Code
Convert folder of images to AVI
Products and Environment
    Software
  • Vision Development Module
  • LabVIEW
Code and Documents
Overview
The example demonstrates how to save a series of images as an AVI video file.
Description
In case it is necessary to convert a series of images to AVI video file you can accomplish the task with the functions of the Vision Development Module.
The example reads every image in the specified folder and writes each image as a video frame to the AVI file.
Requirements
 Software
  • LabVIEW 2012 Base Development System (or compatible)
  • Vision Development Module 2012 (or compatible)
 Hardware
  • No hardware is necessary to use this example VI
  1. Select the folder with the image files (e.g. choose the 'data' subdirectory)
  2. Select the path of the AVI video file generated from the image files
  3. Run the VI
**The code for this example has been edited to meet the new Community Example Style Guidelines. The edited copy is marked with the text 'NIVerified'. Read here for more information about the new Example Guidelines and Community Platform.**
Staff Certification Engineer
Comments
Cheng6688
Member
Member
on
I have downloaded the VI, but have not figured out how to use it properly. Would you explain in details how to specify the following contents: Image String Specifier, AVI output path, Image input folder?
I have just figured out how it works. No worries.
Thanks.
