Example Code
Convert TDMS File with DAQmx Raw data Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Description
Overview
Very simple utility to read in a TDMS file and the write out data to a new TDMS file (which does not use the DAQmxRaw Data type). This will convert DAQmxRaw data which is problematic for reading with other tools.(http://www.mathworks.com/matlabcentral/fileexchange/44206-converttdms-v10).
Description
Open a TDMS file with DaqMxRaw data in it, write all of the data to a new file.  The DaqMxRaw datatype is used for high throughput data file writing.  Raw ADC Data is stored with scaling factors in the DAQmxRaw datatype.  The decoding information for this datatype is not provided by NI in the tdms documentation at: http://zone.ni.com/devzone/cda/tut/p/id/5696.  This VI demonstrates how a simple VI can be used to open a TDMS file which contains data in the DAQmxRaw data type and write it to another file (this operation converts the data in the file to the supported data types available to users in the TDMS documentation).
Requirements
  • LabVIEW 2012 (or compatible)
Steps to Execute Code
  1. Run VI.
  2. Select File to be converted.
  3. Copy File name from above and change or append to name.
  4. Press OK to convert button.
  5. Close the VI window to stop the VI.
Additional Information or References VI Block Diagram
VI Snippet
**Updated to use an Event Structure instead of polling a control.
Comments
joe2017
on
Would it be possible for National Instruments to update their documentation for the special daqmx tdms format so it would be in the public domain like the normal tdms format?
likewise
on
I wonder what the conversion utility does. I have tried to convert a 1 GB file and got 1.3 kB out.
crossrulz
Knight of NI Knight of NI
Knight of NI
on
I just updated the VI to use an Event Structure instead of polling.
Due note that this is geared to TDMS files that were made with the DAQmx Logging.  Any additional groups will likely be removed.
GCentral
leo_krupps
on
I tried to run this using an input file that was written from a DAQmx express vi with TDMS logging turned on. I get the error code 2: Memory is Full in the Write TDMS primitive. Any idea what is going on here? The file size is around 3-400Mb and the index file is 5Kb.
This is a simple 2 channel voltage capture task with continuously sampled analog input with sample rate of 100kHz and samples to be collected sitting at 10k.
alphaNOVA
on
I can run the VI but it doesnt seem to write any file (i also activated highlighting, it seems to run fine, no errors and data is passed, but i dont get a file)
murse
on
Hi! I am getting the error code 2: Memory is Full in the Write TDMS. My TDMS files are really large. Is there any solution available ?
Best,
leenjabban
on
to get over the memory full issue you can modify this VI to loop through the data (by setting the offset and count in read TDMS) and exiting the while loop when the read TDMS "end of file?" is True. One thing I had to do is open and close the TDMS file being read in every loop over else I get errors*. I am assuming there is a more efficient way to do this but this is what worked for me.
*note that this is only for the read TDMS not write TDMS too.
Contributors
