Overview
This VI shows how to define a specific error in your code and when this error appears while running the code, you can clear it from the error cluster.
Description
While the best error practice is to handle all errors, there may be times (such as user defined errors) where the user may want to simply clear an error. LabVIEW has a built in function called "Clear Errors" that will clear any error in an error cluster. In order to selectively clear an error with this VI, you need to check the error cluster first for your specific error, and then use the "Clear Errors" function.
The attached example creates a new SubVI that allows a user to input a specific error (or array of errors) and then clear the error cluster when the appropriate error code is seen in the error cluster. The SubVI is implemented as a polymorphic VI and is a good example of dynamically adapting to terminal inputs as well. The input can either be a single numeric error code or an array of numeric error codes to check and clear. This example performs the following:
Requirements
LabVIEW 2012 (or compatible)
Block Diagram
Front Panel
Great stuff Captain! Please add "LabVIEW" to the tags.
Thanks! Added the tag (and a few others.) Also fixed my screenshot (I hate when I can see the selection boxes on case structures in a screenshot.)
Be sure to check out the OpenG version of this VI. I think you need LV2009 to run those. But we tweaked to get a little better performance than these will for the searching.
This site uses cookies to offer you a better browsing experience. Learn more about our privacy statement and cookie policy.
