Example Code
Calling .NET Assemblies From LabVIEW
Code and Documents
Overview
The attached example VI calls the .NET DLL that accompanies it, which is a .NET class built in C# to emulate a very basic calculator.
Description
Although many shared libraries exist, and have the same extension of *.dll, you may or may not be aware that there are in fact two very different ways that DLLs are called from LabVIEW, depending on what language the Dynamic Linked Libraries (DLLs) were written and compiled in.  DLLs written in both ANSI C and the .NET languages (like VB.NET and C#.NET) both have the extension *.dll when compiled, and may appear to be the same on the surface, but are inherently different in the way they are called from LabVIEW.  Unlike a C-style DLL, which is called from LabVIEW using a Call Library Function Node, .NET DLLs are called using a .NET Constructor Node (Connectivity » .NET » Constructor Node in the Functions Palette).  This function, when placed on the block diagram, will allow you to browse for the .NET assembly (or DLL) that you wish to use.  Once you select the DLL, and the class from the DLL that you want to use, LabVIEW instantiates an object of that class, and passes a reference to the object out.  With this object, you can then access all of the properties and methods of the class using Property Nodes and Invoke Nodes.
  1. Download the TI83.dll and the example VI
  2. Use buttons on Front Panel to get/set properties of the calculator and to execute functions
  3. Use Execution Highlighting to observe how the VI uses the TI83.dll to get it's functionality
  4. Run the VI
Requirements
LabVIEW 2012 (or compatible)
.NET 3.5 Framework (or compatible)
Block Diagram
Front Panel
**This document has been updated to meet the current required format for the NI Code Exchange. **
Chris_G
Sr Test Engineer
Medtronic, Inc.
Comments
EWiebe
on
Thank you for the sample, but could you please add the C# source code (complete with solution and project file) ?
Eugen Wiebe
Bernstein AG
CLAD - Certified LabView Associate Developer
GL999
on
Thank you very much for your sample code. I am wondering whether both VC$ and LabView can call the same .net DLL?
George
tduffy
on
There is no source code for the .Net assembly.  Could you please post?
BlackLin
on
I got an error when I try to call the DLL got from other people. The error is saying "This assembly is built a runtime newer than the cirrently loaded runtime and cannot be loaded.
How do I know the current runtime version I have?
How do I update runtime loaded in my machine?
Black
bmitc
on
I am not trying to hijack your post but am simply posting since it is relevant. I implemented a library in LabVIEW that uses Perforce's .NET API, which is a prototypical .NET API with lots of objects and collections. So the LabVIEW library is a non-trivial example of how to properly handle multiple constructed .NET objects, .NET collections, and how to properly close out .NET references from LabVIEW, which is very important. When writing this library, I found there were very little non-trivial examples of how to use .NET from LabVIEW, although your post is nice since it shows how users can write their own .NET assemblies to be called from LabVIEW.
The library can be found here: https://decibel.ni.com/content/docs/DOC-43970
elibarber
on
For those asking for the source code for the dotnet assembly, I was able to decompile it with JetBrains dotPeek. xD
// Decompiled with JetBrains decompiler
// Type: Calculator.TI83
// Assembly: TI83, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
// MVID: A46ECFF7-7D07-41CD-ACB2-66DC4E3FD6FB
// Assembly location: C:\Users\ebarber\Downloads\Calling dotNet assemblies in LabVIEW\Calling dotNet assemblies in LabVIEW\TI83.dll
namespace Calculator
  public class TI83
    public string manufacturer = "Texas Instruments";
    public string model = nameof (TI83);
    public int add(int x, int y) => x + y;
    public int subtract(int x, int y) => x - y;
    public int multiply(int x, int y) => x * y;
    public double divide(double x, double y) => x / y;
    public double square(double x) => x * x;
elibarber
on
EDIT:
To those who are new, you will find that a decompiler might translate to newer .cs code, in order to use something that is compatible with labview, you would need framework dotnet. something like this should be compatible with
csc.exe /target:library Calculator.cs
You will need to find the directory for it too to compile. Mine was in C:\Windows\Microsoft.NET\Framework64\v4.0.30319
  public class TI83
    public string model = typeof(TI83).ToString();
    public int Add(int x, int y) {
      return x + y;
    public int Subtract(int x, int y) {
      return x - y;
    public int Multiply(int x, int y) {
      return x * y;
    public double Divide(double x, double y) {
      return x / y;
    public double Square(double x)  {
      return x * x;
