I'm trying to run a simple Visual C++ file in LabVIEW by using CIN. However, I'm having trouble compiling the source code in Windows. I followed the online help and created a Makefile (buffer.mak):
I saved this file in the same folder as my .c file, and then when I tried to open the .mak file into Visual c++ I recieved the following prompt:
The project 'buffer.mak' must be converted to the current Visual C++ project format. After it has been converted, you will not be able to edit this project in previous versions of Visual Studio. Convert and open this project?
I selected Yes, and then recieved the error: Cannot load the project due to a corrupt project file
I'm at a loss of what to do, seeing as I can't load the .lsb file into LabVIEW without a working Makefile.
Any amount of help would be greatly appreciated. Thanks.
