08-16-2009 10:31 AM
Does National Instruments plan to provide DDK support (xseries.cpp/.h) for the new X Series boards? How about documentation for the STC-3?
--spg
08-17-2009 01:45 PM - edited 08-17-2009 01:45 PM
08-17-2009 02:08 PM
I have several different custom OS X drivers for M-Series boards.
One of these drivers supports very high speed event-counting using DMA. Since the M-Series counter FIFO is only 2 samples deep, at very high speeds (e.g. when sampling near 1MHz.) the FIFO gets overrun when there is any significant latency on the bus. I note that the X-Series has a 512 sample FIFO, which would solve this problem.
Also, I know my clients would be extremely interested in the simultaneous a/d sampling on multiple channels available on the new boards.
Finally, the 2 extra counter/timers available would be extremely useful for some complex tasks.
--spg
11-26-2009 02:07 PM
We have been happily using the MHDDK for a while in order to use the PCI-6220 board under Linux. However, we've had to upgrade to the PCI Express bus, and so we purchased the PCIe-6320 to replace it. Unfortunately I have found that I can't use this MHDDK driver for this X series board. Are there _really_ no plans to support it? At the very least, I have been looking for the register-level documentation. Is this available somewhere?
thanks,
Steve
11-26-2009 02:32 PM
11-26-2009 02:52 PM
Thanks, we'll look into it but the cost difference might be prohibitive.
I'd rather get complete documentation (i.e., register level description) for the product we have already purchased, if it's at all possible. Are there any plans to release this information?
Steve
11-30-2009 05:29 PM
Joe Friedchicken
NI Configuration Based Software Get with your fellow OS users
[ Linux ] [ macOS ]Principal Software Engineer :: Configuration Based Software
Senior Software Engineer :: Multifunction Instruments Applications Group (until May 2018)
Software Engineer :: Measurements RLP Group (until Mar 2014)
Applications Engineer :: High Speed Product Group (until Sep 2008)
11-30-2009 05:48 PM
11-30-2009 06:00 PM
indeed, this is awesome. I have some clients who will be very happy to hear this news.
thanks!
03-26-2010 10:43 PM
Do you plan to support the PXI6682 and PXI5404 boards for Linux? Thanks.
