From Friday, January 17th 11 PM CDT (January 18th 5 AM UTC) through Saturday, January 18th 11:30 AM CDT (January 18th 5:30 PM UTC), ni.com will undergo system upgrades that may result in temporary service interruption.
Driver Development Kit (DDK)
NI PCI-6528 , NI PCI-6229 - intervalzero RTX - NO IRQ is allocated
We are using NI PCI-6528 , NI PCI-6229  under interval zero RTX 32 bit on win 7.
For both cards, we are using RTX driver that doesn't support interrupts and we use Polling.
Is it ok that no specific IRQ is allocated to any of these two cards?
Windows will not allocated IRQ since these cards are defined as RTX cards.
In RTX configuration we specifically defined that RTX will not allocated IRQ since there is no free IRQ in the system.
Please help with this issue.
Best Regards,
Efrat Gur
(6,718 Views)
Hi Efrat,
As long as your application's requirements do not depend on interrupts for its behavior or performance, there won't be a problem.
Are there specific features you are worried about?
Joe Friedchicken
NI Configuration Based Software
Get with your fellow OS users
[ Linux ] [ macOS ]
Principal Software Engineer :: Configuration Based Software
Senior Software Engineer :: Multifunction Instruments Applications Group (until May 2018)
Software Engineer :: Measurements RLP Group (until Mar 2014)
Applications Engineer :: High Speed Product Group (until Sep 2008)
(6,700 Views)
We are working with NI PCI 6528 with interval zero RTX2016 working on windows 7 , 32 bit.
Currently we are reading the I/O card frequently.
We can allocate an IRQ in exclusive mode for NI PCI-6528.
We are wondering if you can guide us where we can find the driver's code that implements an interrupt whenever there is a change in the discreet value.
Best Regards
Efrat Gur
(5,296 Views)
