This is quite a pain.
Here is what I had to do:
1. Configure kernel sources. When installing Suse 11.2 from DVD, select the
'Software' option (at the final installation screen) and add Base
Development, C/C++ Development, and Kernel Development. This loads a
matching source tree to the running kernel. Then Log in into a root
console (superuser) and configure the compile environment to reflect your
actual set up.
cd /usr/src/linux
make cloneconfig
make modules_prepare
2. Add Module.symvers to /usr/src/linux according to this method:
cp /boot/symvers-2.6.31.5-0.1-desktop.gz /usr/src/linux
mv symvers-2.6.31.5-0.1-desktop.gz Module.symvers.gz (rename file in /usr/src/linux)
gunzip /usr/src/linux/Module.symvers.gz
If you don't do this you will get missing Module.symvers warning and your
module will not install.
3. nirlpk.c has errors. Remove all variables that had errors. Just that
simple - remove the variable or the whole line if it's there by itself.
See attached nirlpk.c and http://forums.ni.com/t5/Driver-Development-Kit-DDK/Problem-with-the-acquireBoard-in-Linux/m-p/842080...
4. Edit install.sh and unistall.sh : the line with 'source Makefile.in'
generates a file not found error. Edit to read: 'source ./Makefile.in'
See attached files.
I ran ./lsdaq and there is life!
I have not tested uninstall yet.
I am not a Linux wiz. If you find errors in this please post the 'right way'. Part of the reason to post this is in case I blow up my system yet again...
Good luck.
- Erick
