11-15-2010 05:42 PM
I am using a VXI Interface tech SR2510 LVDS card with teststand and keep getting the following error when the intial diagnostics test trys to run. "Device I/O Driver error" I tried to use the Visa Interface and the interactive control in NI MAX but was not able to send SCPI commands. What can I use to communicate with this card. The resource manager does successfully execute and I see my instrument in the devices list so I am confident it is not a VXI problem.
11-16-2010 02:06 PM
Hello DF1963,
Can you communicate with the card through its driver/interface? Also, please review the following NI-VISA Help topic: Introduction to Programming VXI Devices in VISA to ensure that correct commands are being sent. If your device is correctly configured in MAX, I would also recommend verifying with the card manufacturer as well.
Ali M
Applications Engineer
