Driver Development Kit (DDK)
Duty cycle measurement using RLP
Hi All,
I 'm using a PCI-6229 in RTX environment and, I would like to measure a duty cycle.
Is there any exemple file?
Your help is welcome
FV1234
Message 1 of 12
(12,249 Views)
Hey,
I would answer this ...
Regards
Richard Keromen
Message 2 of 12
(12,226 Views)
Hello Richard K,
I sorry but I would like to program my board with register level because I'm in RTX environment. I can start with gpctex3.cpp but I have no informations to do a buffered semiperiod measurement.
Thanks for your help.
FV1234
Message 3 of 12
(12,219 Views)
As you noticed, there are no examples on how to do buffered counter operations for M Series in the MHDDK examples.  However, the M Series counter functionality is based on the same technology used in the 660x counter/timer boards.  Below is a link to the 660x Register Level Programming manual, which should help point you in the right direction.  I hope this helps.
http://digital.ni.com/manuals.nsf/websearch/4CE1C778F442B01386256C870060F9F3
Message 4 of 12
(12,211 Views)
I used also the DAQ-STC Technical Reference Manual
Message 5 of 12
(12,187 Views)
Hello Jeremy,
My acquisition works fine but sometime, the first acquired point is the High level and sometime, the first acquired point is the Low level. I created a semi period task with MAX and with each acquisition, the first acquisred point is the same level.
In my code, I programed the gate polarity at 1.
Do you know what is the source of my problem?
Thanks for your helps
FV
Message 6 of 12
(12,173 Views)
up
Message 7 of 12
(12,152 Views)
Hi Fv1234-
Are you using a software arm or a hardware arm signal?  You should be able to set a hardware arm on the input signal and choose a level/edge that meets your needs.  Can you please give a bit more info about how you're configuring the counter?
Thanks-
Tom W
Message 8 of 12
(12,077 Views)
Hi Tom,
I 'm using a software arm. But with MAX, I have also a software arm???
To use a hardware arm, can I put my waveform on the auxiliary pin and configure the second gate of the counter?
Thanks a lot.
FV1234.
Message 9 of 12
(12,046 Views)
Hi Tom,
It works, I configure the second gate and now every time, my acquisition starts at the same level.
Thanks a lot
FV1234
Message 10 of 12
(12,043 Views)
