05-26-2009 08:00 AM
Solved! Go to Solution.
05-26-2009 09:16 AM
Hi Computer Dude-
Which MHDDK example are you using? Make sure you remove the call to adcReset() as it is only applicable to 625x devices. Also, make sure the convert output polarity (selected by aiPersonalize()) and the gain setting and scaling coefficient lookup (see ai.h and scale.h) match the values you're going for.
I also posted some 6225-specific tips in this thread.
Hopefully this helps-
