i am using MHDDK samples to access a PCI-6250 card.
The correction for offset and gain is always done in the function "aiPolynomialScaler", which returns a physical value. For my project however, I do not need a physical value. Instead, I need the raw 16-bit values from AI, corrected for offset and gain.
Unfortunately, the gain and offset data is located in the EEPROM as a floating point number, with no additional information in the documentation.
void aiGetScalingCoefficients (const u8 *eepromMemory, u32 intervalIdx, u32 modeIdx, u32 channel, tScalingCoefficients *scaling)
u32 calOffset = 0;
calOffset = getCalibrationAreaOffset (eepromMemory);
u32 modeOffset = calOffset + kAiModeBlockStart + (modeIdx*kAiModeBlockSize);
tMode mode;
mode.order = eepromMemory[modeOffset++];
mode.c[0] = getF32FromEeprom (eepromMemory, modeOffset);
modeOffset += 4;
mode.c[1] = getF32FromEeprom (eepromMemory, modeOffset);
modeOffset += 4;
mode.c[2] = getF32FromEeprom (eepromMemory, modeOffset);
modeOffset += 4;
mode.c[3] = getF32FromEeprom (eepromMemory, modeOffset);
tInterval interval;
u32 intervalOffset = calOffset + kAiIntervalBlockStart + (intervalIdx*kAiIntervalBlockSize);
interval.gain = getF32FromEeprom (eepromMemory, intervalOffset);
intervalOffset += 4;
interval.offset = getF32FromEeprom (eepromMemory, intervalOffset);
scaling->order = mode.order;
for (u32 i=0; i <= mode.order; i++)
scaling->c[i] = mode.c[i] * interval.gain;
if (i == 0)
scaling->c[i] = scaling->c[i] + interval.offset;
return;
How can I get the raw gain and offset values?
Or is there any other (easier) way to do this?
Best regards
