05-10-2022 07:24 PM
I need to do pulsed SMU measurements using a PCIe-4139
I have NI-DCPower v20.7 installed but the code I am using interfaces to it using a Interop file created using Measurement Studio for nidcpower 1.6
Some target systems still have older versions of NI-DCPower installed so want to limit how far I update the interop file to.
Alternatively, are the dll EntryPoints, nidcpowerConstants, and nidcpowerProperties documented anywhere so I can add only what I need?
05-11-2022 04:20 PM
Yes, look for nidcpower.h installed on your system.
05-11-2022 04:53 PM
@kirsh - where should I look to find nidcpower.h?
Normally I look in the in the install zip but the ni-dcpower uses an online installer
05-12-2022 07:11 PM
I ran the niDCPower driver install (v 20.7) on my development PC but it only installed the .NET examples
Where can I get nidcpower.h?
05-13-2022 10:29 AM
Did you check under
C:\Program Files\IVI Foundation\IVI\Include\nidcpower.h
or
C:\Program Files (x86)\IVI Foundation\IVI\Include\nidcpower.h
