From Friday, January 17th 11 PM CDT (January 18th 5 AM UTC) through Saturday, January 18th 11:30 AM CDT (January 18th 5:30 PM UTC), ni.com will undergo system upgrades that may result in temporary service interruption.
Digital Multimeters (DMMs) and Precision DC Sources
|V| Compliance Package 1.83
I am trying to upgrade an older test station to use the PXI-4070 DMM (instead of a PXI-4060 DMM) installed in a PXI-1010 chassis:
  Windows 2000
  Labview v6.1
  NI-Labview Run-Time Engine 6.1
  NI-DMM 2.1.0
  NIDAQ 6.9.3
  NI-VISA 3.0.1
  |V| Engine 2.0
The station was originally running:
  Windows 2000
  Labview v6.1
  NI-DMM 1.6
  NIDAQ 6.9.2
  NI-VISA 3.0.1
  |V| Engine 1.61
NI-DMM 1.6 doesn't support the PXI-4070, so I decided to upgrade to NI-DMM 2.1.0, which required me to upgrade to NI-DAQ 6.9.3 and |V| Engine 1.83.  Since I couldn't find |V| Engine 1.83 on the N.I. website, I installed |V| Engine 2.0 as there was no warning as to what version Labview is necessary.  I think installing |V| Engine 2.0 was a mistake because I'm not convinced that it supports Labview 6.1.  'The PXI-4070 self test.vi' returns Self Test Result 301 (should be 0).
How do I get a copy of |V| Compliance Package 1.83?
(6,804 Views)
I'm not sure why you'd go looking for  IVI Engine 1.83, as all the components needed for our drivers should be installed automatically. When you installed NI-DMM 2.1, did you get any particular error that made you think you needed to get a different IVI Engine?
If the driver wasn't working properly, it might be because of a change mentioned in the NI-DMM readme:  "The NI PXI-4070 was upgraded and new revisions of the device beginning with 191485A-01 are incompatible with versions of NI-DMM prior to 2.3. NI-DMM 2.3 and later provides support for all revisions of the NI PXI-4070." You can find the readme by searching "dmm readme" on ni.com, choosing a driver (3.0.1 is what I chose), and opening readme.htm.
To make sure that NI-DMM 2.3 will run LabVIEW 6.1, go back a page (or to ni.com/updates) and search for "DMM 2.3" and click the appropriate link. You'll see that both NI-DMM 2.3 and 2.3.1 support LabVIEW 7.0 or later. Not what you were hoping for, but LabVIEW 6.1 is quite old. You have two options that I can see at this point:
1. Upgrade LabVIEW versions
2. Try to use NI-DMM 2.3 on LabVIEW 6.1.
If you choose option 2, you need to realize that it is completely unsupported. The forums can be a place to seek support, but not many people are going to have experience with or even remember LabVIEW 6.1. If you install NI-DMM 2.3, all the VIs will disappear for versions not explicitly supported. So if you plan to use NI-DMM 2.3 on LabVIEW 6.1, I suggest you copy all of the files and folders dealing with the NI-DMM driver to another location and once you've installed 2.3, copy the files and folders back so that LabVIEW will populate its palettes with the VIs you need.
I hope that helps!
Mark E.
Precision DC Product Support Engineer
(6,788 Views)
Thanks Mark,
The first time I tried to install NI-DMM 2.1 I got an error message stating that |V| Engine 1.83 or newer was necessary.  This corresponds with the documentation on NI-DMM 2.1 minimum requirements.  Since NI-DMM 2.3 doesn't support Labview 6.1, I am going to recommend to my boss that we upgrade Labview.
(6,783 Views)
