03-19-2018 10:13 AM
I am looking into the possibility of utilizing the USB-4065 as the reference device in a calibration system which is under development. The client which will interface with the USB-4065 runs a Linux OS. Does a version of the NI-DMM linux driver exist or are any linux compatible libraries which supports the USB-4065?
Solved! Go to Solution.
03-20-2018 09:21 AM
benwjj42,
NI-DMM 2.5 is available for Linux. However, this driver is pretty old - it does not support the USB 4065, and most of the Linux distributions it supports are pretty outdated.
Your best bet will likely be to either use a card that is supported by NI-DMM 2.5 such as the PCI-4070, or look into the possibility of bringing Windows into the equation somehow - this would give you the most options.
VanCamp
03-30-2018 08:24 AM
Thank you, it looks like we will have to look into other DVMs.
03-30-2018 06:34 PM
Are you on PXI?
Will a PCI / PCIe device do?
Or must it be USB?
06-02-2022 01:47 PM
Has anything changed over the last couple of years? The readme files for the linux drivers seem to indicate support for the USB-4065, but I think I have installed all the drivers (on Ubuntu 21.04) and the NI hardware configuration utility is telling me the USB devices are "unsupported". Any help would be appreciated.
06-02-2022 02:27 PM
This is the NI-DMM for Linux/x86 64-bit Architecture Readme, Version 21.3. It supports modern 64-bit Linux distributions.
Unfortunately, USB-4065 is not supported, and it is not listed in the document. Where did you see it listed?
06-02-2022 03:19 PM
Ah, thanks for the link. I had just gone to the NI-DMM downloads page, selected Linux, and clicked the readme link but missed there were two different readme's available (one for non-Linux and one for Linux).
Are there any plans to support these devices in Linux? Or is there any other way to communicated with the USB-4065's using a Linux OS / Python?
06-03-2022 10:00 AM
Unfortunately there are no plans at the moment to add support for USB-4065 to Linux.
