Digital Multimeters (DMMs) and Precision DC Sources
PXI DMM in a LXI chassis
Hi - i'm looking into an application where space constraints would inhibit me in used even the smallest NI PXI chassis - and it needs to be ethernet controlled (so no USB-4065 dmm for instance)
Is it possible to mount one of the Ni PXI DMM's in e.g. a Pickering 2 slot LXI chassis (which accepts PXI cards) with success?
Would I use the NI DMM drivers still?
Why is NI not really supporting LXI / having LXI products in store?
CLA, Teststand and advanced SQL
(921 Views)
I'm not familiar with this LXI chassis.
The only PXI (as opposed to PXIe) DMM being sold is the PXI-4065.
For it to work, the 4065 would need to be on the PCI/PXI bus of whatever computer resides on the LXI chassis and you'd need to install the NI-DMM driver on this computer, assuming it runs a supported OS. Then you'd need to write your own software that makes the instrument available over ethernet to perform whatever it is it needs to do, which I assume on a TCP/IP network. Python can be a really good tool to do this.
Is there such a computer running the LXI chassis? What are its specs? What OS does it run? Is the ethernet connector a TCP/IP network?
I hope this is helpful.
Marcos Kirsch
Chief Software Engineer
NI Driver Software
(871 Views)
