10-11-2011 04:35 AM - edited 10-11-2011 04:44 AM
Hey,
I work with NI PXI3110 system, DMM PXI4070
I want to measure a DC voltage waveform.
I want to know how can I leave the measurement running and get/ fetch the availble data from RAM at the same time.
Something like double buffering, measuring and reading data at the same time. When I have a certain number of samples, I want to fetch them.
The measuring process must go on. Something like an event structure for buffersize where i can fetch data when i have N samples available in the buffer/ ram. With the given NI DMM functions like "configure waveform" I must first define the number of waveform points, i can´t define positive infinity.
How can I realize that in a labview programm with the given opearation and proberty nodes.
thanks for posting ideas.
10-11-2011 10:07 AM - edited 10-11-2011 10:10 AM
Hey Benni,
Unfortunately, no, you cannot continuously stream waveform data from the PXI-4070. See KB 333L7P2O for more information.
You can continuously acquire in DMM mode, as described in the KB. In DMM mode, you can sample only up to 10kS/s, so if you need to sample faster than this, let us know the details on the signal you're sampling (voltage, required sample rate, etc) and we can provide other alternative modules.
