03-07-2011 11:27 AM
Hi, I am working on a project where in part it has to measure resistance values in different parts of the circuit. Now, the company where I am currently working at wants to get the NI USB-4065 USB. I use visual studio 2005 c# to develop applications and I needed to know if I needed measurement studio or are there drivers (dlls) to just get resistance values and general circuit measurements. I don't need the controls or anything, just to programatically read the values from the NI USB-4065 USB device when i need to in the application.
Any help would be appreciated. Thank You.
Solved! Go to Solution.
03-08-2011 07:48 AM
03-09-2011 12:37 PM
Great! Thanks for the reply and information. I got one more question.
I am asking since I can't test this yet since I don't have the hardware but I have to be ready.
Can I have 1 pci and 2 usb 4065 connected all at the same time? The project will involve taking series or resistance throughout a circuit and it will never be touched. I'ts for quality control of a device that's being manufactured and since its more than two places where resistance measurements will be needed, the company will need more than one 4065 but they already said they have a pci card, the rest will be usb.
Thank you for your time.
03-09-2011 01:46 PM
Yes, you can have multiple NI 4065 DMMs in your system. When you use the NI-DMM API, you open separate handles to each DMM by using its name. Its name can be configured inside Measurement and Automation Explorer (MAX).
Also, you can go ahead and install NI-DMM today. It's a free download on ni.com. NI-DMM (and most of NI drivers) support simulation. You go to MAX and create your three simulated 4065s. Then you can start writing your program right away. Since these devices are simulated, they won't return the real voltages (obviously) and will not react realistically to hardware triggers if you are using them (obviously) but they will behave close enough to the real deal to allow you to write a lot of the code and to get familiar with the API. No need to wait until you get the hardware - you can be really ready for it by using simulation.
03-11-2011 08:09 PM
I don't know if I should ask him again but it has to do with the same topic. i'm just following along what you said and I created 2 smiulated devices to start testing andI get "An attempt was made to load a program with an incorrect format. (Exception from HRESULT: 0x8007000B)" when I try to test. It happens when invoking the device (myDMM = new nidmm(txtInstrumentDescriptor.Text, true, true));
Where should I go to ask this? Can you help?
thank you for all the help.
03-12-2011 12:39 AM
Edit: by him i meant here
03-14-2011 09:36 AM
Edit 2: Fixed the problem, had to compile teh app as a x86 platform. I am using x64 computer and when it compiles it tries accesing dll and it won't work. have to make it so the program is compiled in x86 instead of any cpu (if u using 64 bit os)
03-14-2011 10:58 AM
I'm glad that worked for you, and that you figured out the problem.
I haven't tested it, so there may be extra steps, but if you want to use it as a 64-bit executable, you should be able to change the nidmm.cs file to use nidmm_64.dll instead of nidmm_32.dll.
Please let us know if you have any more questions.
08-23-2011 10:37 AM
Hi all,
I have a USB-4065, and I need to integrate it into a TestStand sequence.
Where can I get the nidmm_32.dll?
I have installed driver 3.0,2, but making a search I could not locate this file.
Thanks for your help
08-24-2011 09:42 AM
fmb_al:
nidmm_32.dll is installed to <IVIROOTDIR32>\Bin
From the readme:
<IVIROOTDIR32> is an alias for the following National Instruments file folder location:
Note | $(IVIROOTDIR32) is configured as an environment variable on the target system. |
If you upgraded an installation of IVI, your files may be located in the following location:
Hope this helps!
