04-20-2020 07:33 PM
Hi community,
Sorry for a dumb question here. But, whenever I read measurement values from a virtual DMM, it always gives me R=50 ohm, Vdc = 5V, Idc = 500mA. Are these the default output values for demonstration purpose only? I'm using a virtual DMM, not a physical one.
Is there a way to connect to a virtual resistor with certain values, such as 1, 10, 100, 1k ohm just to demonstrate the DMM block is working fine? I will also be using a NI switch later together with the DMM.
Thank you.
04-20-2020 09:14 PM
04-21-2020 05:28 PM
Thanks! That makes sense.
