I've been trying to set the Device Numbers for the NI-4060 DMMs using MAX (v2.1) However if the Device Numbers are above 15, the NI-DMM (v1.6) SoftPanel won't detect the DMM. I've also found that if the Device Number is 10 or higher, the NI-DMM SoftPanel reports the Device number as being 1. The test panels in MAX work fine no matter which device number I use & I can program the DMM using LabView using any device number, It seems to be a problem with the SoftPannel.
Do anyone know a solution to this?
Simon Holman
Software Engineer
Certified LabVIEW Developer
Certified TestStand Developer
measX GmbH & Co. KG.
http://www.measx.com
