01-11-2011 10:26 AM
Greeting all,
While excercising streaming with PXI-6552, I met the error in the title (error code -238805) on and off. Any idea on why it happens and what I can do about it?
Tian
01-12-2011 09:44 AM
Tian,
Do you only get this error when you are streaming data or do you also get the same error if you try and use the card for any other HSDIO program? Also, could you tell me what PXI Chassis and PXI Controller you are using with your system. If you happen to be in a PXIe Chassis with the PXIe-8133 Controller there is a known issue where you can get a similar error. This KnowledgeBase linked below provides additional details.
MIG Hardware Error -238809 with PXI NI-HSDIO Devices and the NI PXIe-8133:
http://digital.ni.com/public.nsf/allkb/28877A20164C595E862577D700001523?OpenDocument
If this is not the case the general the troubleshooting steps I would recommend would be the following:
Let me know the results of these tests. Thanks!
