04-15-2008 09:47 AM
04-16-2008 12:51 PM - edited 04-16-2008 12:51 PM
mike.s,
Welcome to the NI forums. In LabVIEW you can specify multiple ports when running one of the shipping examples that come with DAQmx.
In LabVIEW go to:
Help > Find Examples
In the Example Finder go to:
Hardware Input and Output > DAQmx > Digital Generation > Write Dig Port.vi
Here you can specify how many ports you want to write to by using a “:” in between port numbers.
I hope this helps!
04-16-2008 04:29 PM
04-17-2008 10:15 AM
04-17-2008 10:17 AM
04-17-2008 11:51 AM
Hello JOelei,
If you're referring to these tasks not showing up in a LabVIEW channel constant control then the I/O name filtering may be the issue. For information on how to change the filtering see this KnowlegeBase article: Virtual Channels Missing in DAQ Channel Name Control or Constant. I would also make sure that you're using a traditional DAQ Channel Constant and not a DAQmx Channel Constant.
In the future you may get a better response to your forum posts by creating a new thread rather than posting to the bottom of an unrelated one. Creating a new thread for a new question also helps keep all of the information on the forums readily available and searchable for users in the future.
If you're still having trouble with this issue, please feel free to post back with more information. It would be good to know what type of task you’re creating, what hardware you're using, and what versions of LabVIEW and Traditional DAQ you're using.
Have a great day!
