From Friday, January 17th 11 PM CDT (January 18th 5 AM UTC) through Saturday, January 18th 11:30 AM CDT (January 18th 5:30 PM UTC), ni.com will undergo system upgrades that may result in temporary service interruption.
Digital I/O
input and output simultaneously with burst mode
I am working on project to test the burst mode of a 6533 board.
I need to output data, then input these data with burst mode. I simply merge two LV examples,burst mode input.vi and burst mode output, into one Vi.
I set the output as group 0 and input as group 1. The PCLK source is internal. I also wired Ack1 to REQ2,ACK2 to REQ1,portA to port C,port b to port D. After running, the result of input data is not equal to the output data.
What's the problem?
(3,201 Views)
Zhichao
Is the data you are getting entirely incorrect, or just part of it? Also, have you tried just doing 8-bit handshaking only using ports A and C? This may give us some more insight into what is causing the bad data.
Brian
(3,201 Views)
The data was incorrect at all. I also tried 8-bit handshaking.
As far as I know, the daq is signal thread. I ever used a pulse train to simulate ACK or OBF signal from external device,no problem. But if I useed a count board(6602), which is in the same computer as DIO96, to produce the pulse train, the result was wrong
(3,201 Views)
