hi,
I am currently using PCI-6534 with LabVIEW 7.1. I am using the PCI-6534 to do a buffered pattern output using 2 ports i.e port 0 and 1. Port 0 and 1 is configured to be pattern output with external clocking. NI website has an example of doing a fast buffered pattern output by using an icon called buffer control with the parameter set to reserved which allows me to skip the step of reconfiguring the PCI-6534. However, after running the code, if the last data for the particular line is suppose to be high, it will not retain the last state of the data. It will return back to low. My assumption of this vi is, if the last state is set to high, and if I do not call anything else in my program, it should not change its state.How can I avoid this problem? I also looked at the DPULL which allows all the line to be set to high or low by pulling it to ground( default) or to 5V. But I only want certain lines to be high as default. I attached a screen capture of the code I used for the pattern output code. Thanks for any recommendation .
